1 - 2 of 2 Posts
So I've been having trouble with my transmission the past 8 months. Symtoms were going into limp mode often, going into neutral on the highway, only when in 4th / overdrive.
I've changed the input / output sensors, solenoid pack. 3 wks ago brought it to a tranny shop and they said the tranny was 3 qts low, but tested strong. Does anybody have any other solutions to this problem?
Since replacing the solenoid pack, it has been running better, only going into limp mode once every couple of days, and only going into neutral at highway speeds a few times. I have an extra autostick TCM that I got a few years ago. Should I try swapping out the computer? thanks.
Maybe get the actual transmission codes read instead of throwing money at it? :dunno:
And 3 quarts low is 3/4 of a gallon of ATF! Maybe time for a low mile used replacement transmission?
1 - 2 of 2 Posts
