1 - 18 of 18 Posts
As a techno-weenie, it's my nature to be intuned with a lot of cool gadgets. This little peice of magic, I think, would be great for the pure car enthusiast looking to get the most out of his/her vehicle.
It's called the CarChip. Some of you may have heard of it. It's a small device that plugs into the OBDII connectors and it records data from 4 of 23 available engine parameters with intervals anywhere from 5 to 60 seconds. The parameters are:
RPM
Battery Voltage
Throttle Position
Timing Advance
Engine Load
Coolant Temperature
Fuel Pressure
Air Flow Rate
Fuel System Status
Intake Air Temperature
Short-term Fuel Trim
Long-term Fuel Trim
Intake Manifold Pressure
Oxygen Sensor Output Voltage
It was originally designed as sort of a deterrent for people who might be tempted to drive unsafely. But i think a good off shot of that is cheaply monitoring engine performance, without having to go to a garage.
Check it out at
TheCarChip.com
the only thing that kinda sucks is you have to buy the chip and the monitoring software separately.
Its been around for several years now. There are many modifications. Originally made for teen drivers.
The cool thing about it is the ability to analize mods
exactly realsynthetics. records everything about the performance of a vehicle. it even records everything that happened during the last 23 seconds before an accident
So has anybody used it yet?
They have em at Autozone now.
Standard ODB-II datalogger. Not really anything special.
You can get ODB-II cables and software for a laptop to view sensor data in real time, and log it.
And for those that don't have OBD2?? lol...nothing
That brings up another valid queston.
Are we obd2? The few pages I visited seemed to say Dodge post 96 are fine.
Mopar or No Car
I'm sure all the 2G's are. I don't know about the 1G's, but I saw that same list and looked through the exceptions, too.
It's too bad the Chip will only log 4 parameters. :( Hmmm, maybe it's time to get a laptop ...
0000 J_A_M 0000 said:
Does anyone know where the OBD 1 port is at in a 1G?
The little blue thing right near the peddals. All cars built on or after Jan 1, 1996 are required to have OBD2 by federal law. Some earlier models did have it, but were not compliant. http://www.obdii.com/obdii.html
Looks like what you are buying here is a "protocol converter" which allows your laptop to read the information coming from the OBDII connector output. You need a special OBDII connector cable that hooks up to the converter which connects to your laptop with USB or RS232. The windows program displays the info so you can read it.
I suppose you could buy any one of the converters and use the free "scantool" program from here http://www.scantool.net/software/index.htm#download.
I'm gunna research that.
1 - 18 of 18 Posts
