This morning I found coolant leaked all round the parking lot. No problem with the engine temperature when I refilled the coolant. If I run the engine for some time, coolant starts to leak if the engine stops, after 30 minutes, leaking stopped.
I didn't jack up the car and take a look, just see probably the leak is from the middle of front engine.
the radiator should be fine, is that a water pump gasket?
this is a 04 3.5 ES.
