1 - 2 of 2 Posts
well the other day i noticed i had a coolant leak coming from underneath my car it was coming right from the thermostat housing on my 2001 intrepid 2.7 anyway i took the housing off and changed the gasket and thermostat but it still leaks anyone have any ideas could it be the housing it's self ?
Yes. The weep hole for the water pump is in the same location as the thermostat housing. Coolant coming out the weep hole means that the inboard seal on the water pump has failed.
Water pump replacement required immediately.
1 - 2 of 2 Posts
