Every time I put coolant in my car it leaks out some kind of way,I have not seen any leaking on the ground so where is it going? Now I can't drive my car until this problem is fixed.
Go rent a coolant pressure tester from Advance or AutoZone, etc. Hook it up, hold pressure, and see where the leak is coming from.
could be a lot of places....u didn't give much information.....do what scooter-man says first....these cars leak from a lot of different places and it changes between the 3 motors....could be water pump, head gasket, radiator, freeze plugs, etc.....no simple diagnosis....the pressure tester should show u coolant leaking, dripping or shooting out somewhere...could be a hose is bad, thermostat, thermostat gasket, lots of places.....
