1 - 2 of 2 Posts
Start from yesterday, the coolant temperature reading at my Trep 99, 3.2L stayed at the C level instread of went to the middle of the gauge after started. After driving a while, the reading will rise a little, but still one or two lines below the middle line. What could be the problem?
I checked the coolant fluid, it seems like been freezed because only part of the coolant bottle has the green fluid(actually it not fluid, but solid stuff) and the level is much higher than the Max line. What should I do? Thanks!
Id say either the thermostat is stuck open, not allowing it to warm up, or your temp gauge sensor is bad. As far as the fluid, if its got solids in there it probably needs flushed out....Im cant really say without taking a look at it...
1 - 2 of 2 Posts
