After driving for a little while.I popped my hood and my coolant was bubbling.What cause it bubble.Does it need to be changed.
It could have simply been putting coolant into the bottle because its hot. Could have a bad radiator cap or thermostat too. If it does this while running, it can indicate a head gasket leak. I doubt it though, as long as its not overheating or loosing coolant, I would leave it alone. As far as changing it, as long as its clean and the freeze point is good, leave it.
If I'm sitting it will go to the have way mark.Then when driving it will go back to one notch under the have way mark.
