So I was able to get the bolt out of the rear mount but when I try to seperate the lower half it is so tight I broke the tip off of my pry bar! Any suggestions?
That rhythm is INFECTIOUS.
Usually it's easier to do them in pairs - pull both rears or both on one side. Trying to pry just one corner when the other 3 bolts are still tight is nigh impossible.
I think what he means is the lower section of the bushing is stuck to the upper bushing.
The only thing i can think of to do would be to smack the around with a hammer the edges until they loosen up.
O.K.with PB, hammer and 2 foot crowbar the halves are separated. Question is if I go with the after market poly bushings will they squeak or make noise?
