si, the chilton's says that the cam position sensor is located in the front of the timing case cover, directly under the upper radiator hose near the thermostat housing. if i had a scanner i'd scan the pics in but i hope that helps anyway. it also says to unhook the wiring harness from the part, unbolt the retaining bolt then take the part out. i assume you reinstall the same way in reverse order. be sure to disconnect the negative battery terminal before doing this.
