so recently the displat of my factory infinity head unit went out, and i was like "well that sucks, but okay" and now the display on the climate controll jobbie is flickering, as is the OTIS display, everything still works, just cant see the lil' green numbers. anybody know what is wrong?
Have you made sure the connectors to the Body Control Module?
The body control module is located on the passengers side under the dash.
i will have to check. can i get to it from inside the car without tearing it all apart? or is it tough to get to?
Dain bramaged
to get to it, you have to drop the lower 1/2 of the dash..
i'd check your battery terminals and the connections at the altenator.
sounds like quite an undertaking, i will have to look at it when i get home tuesday. thanks everyone for the help, if anybody has any other ideas of what the problem is, they would be greatly apprecieated. ;)
Here's a better How-To:
Body Control Module
REMOVAL & INSTALLATION
See Figure 1
Fig. 1: The body control module is mounted on the vehicle with a push pin and mounting screws
Remove the right end cover.
Remove the right cowl side trim panel and pull the carpeting back, exposing the dash liner.
Cut dash liner along the perforated lines and pull the dash liner back.
Remove the screw through the oblong access hole at the right end of the knee blocker.
Remove the push-in fastener at the lower leg of the module from underneath the instrument panel and maneuver the module down and out.
Disconnect the wires on the body control module, then remove the unit from the vehicle.
To install:
Attach the wiring to the control module.
Install the module and the push-in fastener.
Install the screw through the oblong access hole at the right end of the knee blocker and tighten.
Place the dash liner into position.
Lay the carpeting back into place. Install the right cowl side trim panel.
Install the right end cover.
