i want to take it in to get checked but would like to have an idea on what maybe wrong. when i try to turn it on while driving the light doesn't come on, but when i crank the car cruise light comes on with every other light on the dash.
how do i adjust it?You may want to try adjusting your brake pedal switch up under the dash. Sometimes this switch causes the Cruise to be inoperable. Not saying this is YOUR issue, but worth a check
how much is that to replace?most common cause of failure is a bad clockspring.
