having trouble with cruise control checked brake switch changed out cam position sensor and checked vaccum lines no leaks don't know what to do. when sitting still in neutral turns on put it in drive give it gas goes off. please help [email protected]
Are you convinced that the brake switch contacts work correctly (3 sets of contacts - one or two normally open, the other normally closed) and adjusted correctly?
