1 - 20 of 24 Posts
I need to build my sub box to fit in the back of my trunk. The specs say 1.7 cubic feet is ideal. I just need somebody to figure a box design using inches with it not exceeding 17' inches wide, 14' long and 13' high. So basically width is all there is to change. How wide should each box be? This is for 2 twelves, 1 box each then Im going to attach the boxes together. Kinda Like Dodgeyaussie's was If you remember how he did it except my subs are going to fire into the cab.
  • Like
Reactions: Vertigo_AK47
And you thought all of that math you had in junior high school would never be of any use.......
Oooooooookkkkaaaaayyyyyy. My Bad :doh: , I guess I shoulda put it in the audio section but I assumed it to be a mathish general question.
But check out the convertor --comes in handy!
I looked at it, didnt find cubic feet but damn that thing has about everything else. Thanks for the tip, it will come in handy later for my math homeowork for sure.
Yes. I still am retarded and cant figure out the dimensions Ill need though. I can get some of it through the converter but I just dont know what to do with the numbers.
easy conversions: 12 inches in a foot. for cubic feet you need to go this route:
you can only change the width, so, for out purposes we will call width W. Hell, call it what you want, and after you get done talking to it, plug it into this equation: W*14inches*13inches = 1.7 ft^3.
whoa. you got inches in that equation. we need it all in cubic feet. No problem, up at the top we have that conversion figure. so 14inches * 1ft / 12 inches = 14/12 feet or 1.1667 feet. 13 inches * 1ft/12 inches = 1.0833.
so, we have now W*1.667*1.0833 = 1.7ft^3. simplifies that to 1.2639*w = 1.7
so W = 1.7 / 1.2639 which is 1.3451ft
wow. not too shabby, now all you need is that in inches and we are good to go
we have 12 inches / 1ft * 1.3451 ft the ft cancell out leaving inches, and that gives us 16.1407 inches.
and that I believe is within your specs.
Happy building
AJ
Discussion Starter #14
Man I Love This Sight!!!! You guys Are Awesome. Thanks For The Help. Anybody ever need help with any English Related Questions Feel Free to ask!! Haha
You have to consider the with of the plywood in your calculation too.
No prob!
I have to point out the irony that you're offering help on english and you spelled "site" as "sight" I'm not being a jerk, I do that all the time when I'm typing, I just found it to be amusing.
There's 1728 cu inches to a cubic foot (12 x 12 x 12).
Using the max dimensions you provided, a box that big would have a volume of 3094 cubic inches (17 x 14 x 13 = 3094). Divide that by 1728 and you get 1.79 cubic feet.
Since your dimensions will be outside dimensions, the inside dimensions are a bit smaller when you factor in the thickness of the wood. So that probably brings the inside volume down quite close to 1.7 cu. feet.
Discussion Starter #19
00r/t.mopar.muscle said:
No prob!
Ha!! I did. Got a good laugh at that one. I promise Im good at english that was just a slip-up haha. Im glad you pointed that out, now I can watch that a lil' better.
Discussion Starter #20
Man you all are doing what seriously would have taken me a very long time to figure out. I appreciate it.
1 - 20 of 24 Posts
