Unfortunately, you most likely will not be able to run auxilliary inputs into the DIN plug on the back. The last I knew, Alpine CD Changers could be used along with an adapter instead of the factory unit. However, Alpine does not make an aux. input adapter for the model DIN cable that that specific CD changer uses.
Of course, you can always go the route I'm going and gut the entire car so you can hear music the way it was intended to be heard. When I get the system install underway, I'll be sure and post pics for you guys. First step is installing the Clifford Avantguard 4 alarm with remote start and power window roll up/roll down control. After that, I have Clarion CD player, 6 Disc Changer, Phoenix Gold Signal Processors, 3 Lunar amplifiers, Image Dynamics Horn Loaded Compression Drivers, 6.5" midbass drivers and a single 12" subwoofer to make a home for in the car.
skellyo
