The following pictures are the driver side cylinder head and the bolts I believe I found the proper locations of:
Rear
Front
Intake side
Exhaust side
Rear
Front
Intake side
Exhaust side
I appreciate the assistance! I’m probably not going to worry about the #6 screw as I suspect your right if it even belongs on the car at all. Thanks so much!the bar on the left with the hook and pin are for the intake. its a support. it uses one of those m8 bolts.. #2, #3, #5 going left to right on your bolts. the nut is for something that has a stud sticking out.... #6 is a corse thread. its for plastic. like the front bumper cover? the screw doesnt belong in the engine bay. maybe a plastic cover? the on on the far right may go into the small metal piece with the captive nut... best i can help with rn.
