i still cant get the radio bezel to fit over the 1 din adapter plate what the hell ne one else have this problem how to fix?:crazy:
This should be in the car audio section. :bored:
It sounds like you need to do a better job of packing your wires in behind the radio. It can be a challenge with all the wires coming out of today's aftermarket radios. Pull the radio out and try to make sure all the excess wiring is all packed in an open area either to the side or below the radio slot. Another possibility is that if you're using the RCA jacks on your headunit and the headunit doesn't have them on pigtails, you may need 90 degree adapters...
