· Registered
Hey guys,
On my 94 ES, only the floor vents and defroster vents blow air. My dash vents will not blow air. I was curious if there was a vacuum line in the dash or under hood causing this. I have digital temp controls and every button will light up and work properly but no air through dash vents. Any thoughts?. Thanks in advance.
· Registered
Maybe your auto temp control computer isn't sending the codes to open up the vents?
Or maybe the vent itself is jammed.
Mine usually makes a sound when switching between the different vents.
· Registered
there's a way to recalibrate the air vents. it's a sequence of buttons that you push and then it goes thru a series of stuff and supposedly fixes the problem. i looked it up in my chilton's manual and it didn't say how to do it. maybe look in the owner's manual. i know Si did this recalibration and was very happy with it. i'll ask him and see if he'll post how to do it. stay tuned.
· Registered
Discussion Starter · #7 ·
Hey 97,
I just fixed the problem!. I looked in my Haynes manual and found the section on resetting the vents. Took about 1 minute. Thanks to the rest of the guys who posted input also. This site is awesome and so are all of the Treps on this site!
