1 - 20 of 20 Posts
Could some of you guys that have been here a while compile a list of definitions, please.
Some/most of you guys have alot of info, but some of us don't.
So, could we put together a list of things that maybe we all should know, but maybe we don't????
I'll start with the ones I know...
OTIS-Overhead Temperature Information System
Aight, that's it for me....
All I'm saying is that sometime the acronyms can be a bit confusing.
If this is a repost, please point my dumbA$s in the right direction.
Thank You!
TB - throttle body
AIS motor - automatic idle speed
TPS - throttle position sensor
CPS - crank/cam position sensor
AT - automatic transmission
MT - manual Transmission
VC - valve cover
BCM - body control module
ECM - engine control module
TCM - transmission control module
PDC - power distribution center
ATC - automatic climate control
AC - air conditioning
CC - cruise control
PS - power steering
AS - auto stick
I'm sure there are a lot more that I forgot
This is a very good thread! Maybe we can ask Greg to put a stickey on it.
Speed is Power
I would love to make a thread/sticky it but there are alot of them and it would all have to be in 1 post so that its easier. I would love to set something up tho?
I found these on a website and thought I would share.
MTC - Manual Temp Control
MF - Multi Function Switch
AH - Auto Headlights
R/T - Road/Track (no "and")
ATF - Automatic Transmission Fluid
AWD - All Wheel Drive (used here but we dont have it lol)
Cyl - Cylinder
Def. - Defrost
W - Watts
DOT - Department of Transportation
DRB-II - Diagnostic Readout Box
FWD - Front-Wheel Drive
GND or GRND - Ground
GPS - Global Positioning System
HO - High Output
hp - Horsepower
HTR - Heater
ID - Identification
IGN - Ignition
Inj. - Injector
IP - Instrument Panel
Km - Kilometers
KM/H - Kilometers Per Hour
CEL - Check Engine Light
LED - Light Emitting Diode
MPG - Miles Per Gallon
MPH - Miles Per Hour
NA - Not Available
OEM - Original Equipment Manufacturer
P/N - Part Number
Pwr. - Power (windows, locks, truck, etc.)
RWD - Rear-Wheel Drive
SIL - Shift Indicator Light
TACH - Tachometer
TB - Throttle Body
TC - Turbocharged
Temp. - Temperature
VIN - Vehicle Identification Number
EVIC - Electronic Vehicle Information Center
RKE - Remote Keyless Entry
LH - Platform Chrysler used (rumor says it stands for Last Hope)
LH cars are as followed
1993-1997 Chrysler Concorde
1993-1997 Dodge Intrepid
1993-1997 Eagle Vision
1994-1996 Chrysler New Yorker
1994-1997 Chrysler LHS
1998-2004 Chrysler Concorde
1998-2004 Dodge Intrepid
1999-2001 Chrysler LHS
1999-2004 Chrysler 300M
2002-2004 Chrysler Concorde Limited
Speed is Power
IMO - I got no clue but heres my thoughts. I think noone really knows.
I hear that SE, ES, and SXT really mean nothing. Just some term that the factory used when making the cars. What do I know I got 51 post count lol.
SE - Standard Edition (Special Edition is what most say not sure why lol)
ES - Extra Stuff (Euro Sport is what most say)
R/T - Road Track
SXT - nothing (Same EXact Thing? lol)
Discussion Starter #14
Dain bramaged
well most SE's came with the 2.7 motor, so its not Sport edition.
tps on throttle body means throttle position sensor
tps in tire means tire pressure sensor.
Discussion Starter #16
thanks to all that responded. this helps.
PCM: Powertrain Control Module
Also, to further expand on nhogan's list.
A Gen 1 or 1st Gen is anything above the "---" and a Gen 2 is anything after it.
And SE couldn't be Sport Edition, because otherwise how could we have those cars with the big, ol' 'DODGE SPORT' on the doors.
Side note, in the case of the cars I mentioned above: If it says Sport, chances are it's not.
R/T - Road Track
I think SE is Special Edition, therefore ES is Extra Special.
1 - 20 of 20 Posts
