where is the drain plug in the 95 3.3? can i just use the chemicals from liek autozone? thnks
i did my timing belt a few weeks ago and took out the cooling fans for more room. its only 4 bolts and the fans lift right out after you take off the radiator support? i could not believe how easy it would have made to service the radiator than. i could reach the lower radiator hose and radiator drain with ease from the top.
