221 - 240 of 305 Posts
Discussion Starter #221
If all goes well, should be one of a kind lol I actually had the same thought for a hood, with the lower springs and engine spacers installed, the upper plenum is actually just touching the underside of the hood, so I had to 'fix' that with a bit of persuasion with a hammer to the brace
Discussion Starter #222
Bagged and tagged. Picking up the flat iron on Tuesday, brackets getting made after that. Getting more and more excited!!!
Discussion Starter #223
So, I attended a pretty big meet the other day, car was utterly ignored but that's cool.
Any ways, picked up a set of 25mm spacers to throw on the rear.
Went from this
To this
Next order of business will be new tires right away
I've been looking to do that but never knew what size spacers to get. Are those just the normal spacers or do those come with the lug studs built in as well.
Discussion Starter #225
They are the bolt on style ones. I like this because it makes the current wheels look a little more squared up on the car and future wheels will look that much better!
Discussion Starter #228
Buutt...
H&R does offer them under the product Trak+ part number 5065715 25mm bolt on spacer
That is funny you say that I was out in the garage looking at my project car and I was thinking the exact same thing. It looked as though my rear wheels needed to come out a a bit just to equalize the look
Discussion Starter #232
I always wanted the rear to be wider. After doing the math and looking at wider rims, these were a cheaper alternative.
I just thought your Toe was out of whack when I saw the overhead view of the rear lol
Discussion Starter #233
Sooo, been awhile.
In advance of the drags in July I have a small list of things to do.
V3 Spacer Kit install
Trans fluid and filter
Find a way to 'stiffen' the rear for less launch squat
New tires all around
And making a change and going for a full on IronTrep look for the drags. Heard thru the grape vine there was a car that looked like Iron man at the drags lol So I have the parts, may as well make the rear match with the front
Sooo, been awhile.
My computer just got fixed up i believe.
;) Be prepared for an ironman render on your car :p Got any good pictures of it from the side?
Discussion Starter #239
So I have gotten my car looking more like Iron man and I get new tires on Wednesday, the hard plastic stone combination ones!
Discussion Starter #240
Well, It's been awhile since I updated... to long actually
Got my new tires!!
Well, got the car prepped and took her racing. Did okay, taken down by a very quick srt4 in the second round, really need to tweak the suspension for this season to help with my launch.
Uhm.. not sure what else to say, cars is in a thousand pieces from swapping the dash harness and its been too cold on my days off to work on it.
So mild photo dump?
