I never knew older Chryslers could do the keydance until yesterday, go figure. The CEL has been flickering for as long as as I can remember. I was always told it was an ECU glitch, but it turns out its been throwing codes all this time! Go figure.
The Shadow (1989) is throwing the following codes (and I these seems to be the definitions I found):
12 - Battery has been disconnected within the last 50 starts.
23 - Air charge temperature sensor out of range
15 - No signal from the speed sensor
55 - End of fault code list
Assuming these are correct, I'm guessing I'll need to replace a couple sensors. Would their be any other cause for the fault codes besides faulty sensors?
Also, does anyone happen to know where they are located?
3.0L engine? If so, the speed sensor is probably bolted into the trans and the intake air sensor is in the duct work.
A bad PCM wiring harness could cause it too...check for frayed or loose connections
