For the question on this old thread from a few days ago, if you haven't removed them yet, see my "How To" (below) on the rear C-pillar "applique" covers, if that is what you are referring too. Read down to the last part, because it is very easy to accidentally break off the flat metal mounting brackets that are on the undeside of the covers, unless you slide the covers off off forward very carefully once you remove the screws in the door wells.
The brackets are just held on to the back of the covers by stupid little little plastic nubs (designed by a moron). If they break off (and they probably will), you can epoxy them back on with epoxy for plastic like JB PlasticWeld as described (Need to roughed up both surfaces and can even mix in some tiny scissors clipping from fiberglass body repair fabric for strength.) WalMart has PlasticWeld in the hardware glue or automotive section. (Plastic can be hard to epoxy, and the different JB Plastic Bonder epoxy doesn't seem to adhere as well.)
Yes, you can paint them clear as people have said with a good paint for plastic (obviously that looks best and shiny if done by a pro shop), but you can also just remove the flaking clear coat as described and use the Novus Plastic Polish and then periodically Armor-All or 303 Automotive Protectant (better) and buff. Not super shiny, but OK for me.
Fix for Flaked-Off Clear Coat on Rear C-Pillars
If you don't want to take the risk of breaking the brackets off, you can just leave the covers in place to do all the the work of masking off all around. But pressing down hard on the covers while fine sanding the flaking clear coat or polishing in place could also break off the stupid nubs holding the brackets and then you have to wind up taking them off anyway, so I'd go ahed and try to take them off. In any case, don't press down hard on the covers when routine cleaning/polishing or you can break off the stupid nubs. Of course the plastic applique covers are silly and they should have just had sheet metal there like I believe on the Eagle Vision and other LH cars.
