ok well if you have an intrepid there should be a little white or black plug in the drivers side of the tank remove this plug and the gas should drain out if your tank doesnt have this plug you could remove the fuel line from the fuel rail and cycle the key off and on untill all the fuel is out (very time consuming) or you could feed 12v straight to the fuel pump and fill gas cans with your old fuel thats what i did good luck
