It's making a very loud, very wierd buzzing noise. Sounds like the gears on the lock are stripped or something, it's only when i unlock it. Anyone ever replace a door lock motor and how hard was it???
-Adam
Here's a link to a How To
http://www.dodgeintrepid.net/forums/showthread.php?s=&threadid=13088
The part at the dealer was $85. I didn't find it that easy. Took about an hour +. Removal and replacement of the door panel is a bit of a pain and I have big hands so access to the power lock motor was a bit tight. First time's are always slower. The three silver torx bolts on the inside edge of the door are what hold the unit on. Make sure you have the right torx driver to remove those bolts before you take your door apart.
