What size TB's are on the 3.5 dual intake ?
Thanks for the info. I was given a dual intake but not the tb's. I have two extra 60mm but It seem to fit w/o modification. so it's back to the yard to find a couple of 58's :9lame:
Chewie, didn't you say you had issues using the dual intake ???
they are either 46mm or 48mm ...I forget which at the moment, I'll go check
The 3.5L upper plenum is not a very good option on the 3.3L, you just cant blend the two together within a reasonable thickness adapter. Mine was 3/8" and that was hitting the hood. I'm sure it could be done if you had something closer to 1" but you would definitely need a bulge in the hood. However on the 3.5L its a very impressive intake. On a 3.3L you are better off porting and tuning the stock manifolds or upgrading to the minivan intakes which Can fit with some coaxing and hood cutting. The van intakes give a very noticeable bump in torque which can be a lot of fun.
