Hi i live in finland, here are only few dodge intrepids. So i wan`t to ask you guys can i use e10 fuel to my Dodge Intrepid 2.7 V6 year 2000
Thanks alot.
sure
E10, sometimes called gasohol, is a fuel mixture of 10% anhydrous ethanol and 90% gasoline that can be used in the internal combustion engines of most modern automobiles and light-duty vehicles without need for any modification on the engine or fuel system. E10 blends are typically rated as 2 to 3 octane higher than regular gasoline and are approved for use in all new US automobiles, and are mandated in some areas for emissions and other reasons.[23] The E10 blend and lower ethanol content mixtures have been used in several countries, and its use has been primarily driven by the several world energy crises that have taken place since the 1973 oil crisis.
E10 (10% ethanol) is widely available here in the USA and 100% gasoline is very rare. I've been running my '98 3.2 on E10 for years without any known problems.
Yes, I burn it everyday.
