Hello, I am new here, but need information , I had a check engine light came on and the code I pulled was P0508 Idle Air Control System Circuit Low. The car starts, revs to 2200 then comes back down to 1000 till it warms up about 20 minutes or so then it just stalls and the check engine light comes back on, will not idle after restart, just wants to stall. I have removed the TB and cleaned it, along with testing the IAC motor and the ohms are within spec. 9.7 +/- 1.0 ohm. I was told it needs a New computer by the dealer, at $1000, I need a more economical solution, I live in Ontario. So I am looking for a "aftermarket supplier" for the ECM, any help would be appreciated.
2004 Chrysler Intrepid SXT
3.5 HO Vin.# 2C3HH56G64H678271
ECM # P05114082AA
With GREY Sentry Key
ECM # P05114082AA
