1 - 9 of 9 Posts
I recently swaped a 3.5l into my 2002 se. I did not change my ecu, and i have an engine light prompting error codes about engine running lean i dont remeber the actual codes, but i had my 02 sensors replaced by sts, it was fine for a day enough for me to pass inspection luckily but now its prompting engine codes P0132 and P0152 something about the o2 sensors maintaing low voltage, my gas mile blows. I was reading one special m's thread about how he had the same exact problem and he replaced his universal o2's with mopar ones. I was thinking it was my ecu but after what hat happened to him, im thinking that sts just used universal sensors that wont work with the car, if i order mopar sensors are they all the same, if not do i get 3.5l engine sensors or march them to my 2.7l ecu?
Thanks
James
88pdance said:
I would think a 2.7 pcm would run lean on a 3.5 engine. The sensors are the same so i would say you need a pcm.
I'd suspect the O2 sensors more than the ECU. I'm using a 2.7 ECU on my 3.2 swap, and haven't had any lean-out ..
Others here will concur who've done the 2.7/3.5 swap..
just seems like such a large difference in displacement that the computer may not be able to compensate for it, but I dunno
The ecu will compensate for differences in the engines. Mine has ran great with the 2.7 ecu for 10k miles now also. Have someone thoroughly check the catalytic converters, emission systems, injectors, and o2 sensor system before condemning the ecu.
Does it sound right that sts would put universal sensors in my car casuing the problem rather than mopar sensors.?
I would check with them and see what they put in. Its very likely they put universals in, as they are about 1/2 the cost of the Mopar ones.
they were about 300 bucks for 2 sesors and the installs. if he put the wrong ones in do you think he would give me my money back?
1 - 9 of 9 Posts
