121 - 140 of 276 Posts
Discussion Starter #121
Better start sourcing the other FSM manual parts. Looking at your picture of the original manual it appears to be just the "Body" section. You need at least the "Powertrain" part or whatever they called it then.
Sorry...I don't have any complete FSM manual sets other than for an LH car!
I found the correct one. The 2nd book; (Engine Performance Manual) is the one I need. It has the fuel system and emissions etc.
1980 Chrysler, Dodge, Plymouth Service Manual Set LeBaron, Cordoba, Diplomat
I bought the one on the left. Which will come in handy eventually I'm sure. Full wiring diagrams etc
It's the Fetzer Valve...I keep telling you!
  • Like
Reactions: Intrep_ED
Ed, did you ever check the fuel jets in the carb when it wouldnt start, to see if they are spraying fuel?
IF its a fuel issue, it almost seems like its a supply problem, its filling the carb, running out of fuel in the carb---float sticking, bad pump; carb looks a bit old; if the car sat, could be varnish on the needle valves that the float operates. Did you try to run it with the fuel cap removed (you mentioned you thought you had excessive pressure in the tank)?
Sounds like a fuel issue to me on the video, as it is "trying" to start---again you can spray some ether or carb cleaner down the carburetor and see if it starts; that will be a sure bet that it is a fuel issue; (or see if the jets are spraying)...
Also, I dont suggest trying to rebuild the carb yourself; if there are any carburetor/fuel injection shops left in your area let them do it---we've got a good one here, guy is old as dirt, still rebuilds carbs, they will do the precise adjustments you may not be able to do.
Looks like the original carb, with the lean burn and EGR removed---hence the blocked off hoses, so that shouldnt affect anything.
Discussion Starter #127
Yes. I wouldn't say they're "spraying", but more of a squirting.
I've tried it without the cap.
The jets are squirting, but idk if it's enough... or it's intermittently running into air pockets?
I'll have to look into this one place I know that does carb rebuilds.
Some emissions stuff for you Ed-Doba!
Discussion Starter #129
She started acting up last time exactly like this when I had the same exact amount of gas in the tank. (About 7/8ths full)
I might try to siphon some gas out of the tank. It sure seems like this level in the tank (about 7/8ths full) is where it starts having issues. Of course this could all be just my imagination.
Just looking back at a couple of my previous posts...
Guess what... Charlene decided (after about a 10 minute fight with my foot and the key) to start up and stay running today. Running perfectly now actually, like nothing ever happened! Sound familiar? Yes, it's true! I do believe that now that I've ran the fuel down to a certain level in the tank, she'll operate normally.
I totally believe my guy over at the FMJBody site now... about the jumper. (the little 4-5" long piece of rubber fuel line going from the main line into the tank) It's got to be, or this is some crazy kind of coincidence. I'm going to test this theory by keeping no more than a half tank of gas for the next couple days.
Maybe now she'll stay running and I can get back to the steering and suspension fixes... those are more fun to work on :D
Discussion Starter #131
Tonight I cleaned all the acorns out of the intake manifold. I don't know if this car sat under a tree with it's hood up for a few years or some squrils made a home out of it, but it had a ton of acorns.
Discussion Starter #133
Sounds like some progress, hope it wasn't a squirrel's nest, they can do a lot of mischief.
Looked like it...
I was thinking the only other possibilities of what could have been wrong, is there was something in the gas (water or trash) that cleared up the same exact way it did last time, and this whole idea of "the level of gas in the tank" is just a coincidence.
Or - the needle valve/float mechanism in the carb was stuck.
Things that I'm pretty sure it wasn't:
- The fuel pump all of a sudden starts working great again? Maybe.. now that the fuel level is down to a level that the pressure and pump can work together in harmony.
- Something was getting hot (carb, coil, or the ECU) nope! - it wasn't starting while it was cold the other night, and today I ruled the heat theory out by running the car in idle in my driveway for like 20 minutes and also driving it all over the neighborhood just fine after that.
Discussion Starter #134
Let's hope today proves the gas tank theory. If it runs fine all day today without adding any gas to the tank, we'll know my guy over at FMJ bodies was right, and I need to drop the tank and fix that jumper line...
Discussion Starter #135
One good thing is that the tank on these old J bodies are super easy to get to. It's right under the trunk. I hope (once I get it empty enough to manage) that it doesn't give me any trouble coming down.
I am going to try to run it with a half tank or less for a few days to see if that's really it, before I "yank the tank". I have a pretty good feeling it is...
Discussion Starter #137
Discussion Starter #138
Unbelievable! I go out this morning and she starts right up (like she should!) and I let her sit and idle for 10-15 minutes to get up to temp, hop in and drive her up to the grocery store. Shut her off, go in the store, come back out (10-15 minutes later) and she starts right back up (like she should!) and i drive around the neighborhood for a few minutes like everything is normal and nothing ever happened...
I'm thouroughly convinced it's that jumper, or something at the tank. There's no other explanation for the way it acts with that 3/4 or more in the tank. Right now, with just a hair over a half of a tank, she runs perfectly! No stalls, no no-start conditions, no issues at all! Just like last time... to the "T"!
So my plan is to run the tank down as low as I can, then pull it. Any tips, or other things I might need to look out for when pulling the tank would be helpful. I guess I could wait until my Engine Performance Manual arrives..
