161 - 180 of 276 Posts
Going to fill up the tank now Ed-Doba?
  • Like
Reactions: Intrep_ED
The Bathroom Library will be expanded!
Discussion Starter #165
That's a good question because now that I've fixed that bad plug/vacuum port, the car seems to have come to life. I had one stall stopping at a red light on my way home tonight. Started right back up. No other issues at the ten other lights I stop at on my 20 minute drive home. Pulled into the driveway at home and she idled fine in park for a few minutes until I shut her off.
If the plug was the problem, there shouldn't be any problems with filling up the tank. Of course if I fill it and all of a sudden start having major issues again, we'll know what it is...
Discussion Starter #167
Nobody on the road this morning. On my way to work, I "opened her up" a little WOT. Gotta blow all that crap out of the system... she loved every minute of it!
*arrives at work with smile on face*
Discussion Starter #170
Was wondering how long that was going to take. What color smoke??
Haven't really seen any since I've had it running right. I did see a bunch of white smoke the other day, while I was playing with the carb and having issues.
Have you changed out the plugs and wires yet?
Yessir!
Discussion Starter #171
So what do y'all think about the fuel choices? I do have available, as mentioned, this place here in town that sells "ethanol free" gas, where there's a sign that reads "for off road use only". But there's a hot rod shop a couple doors down, and I hear they all get their gas there.... so...
When I brought up the "Ethanol subject" to an older buddy of mine, he goes "Oh, don't worry, Chrysler started using hardened steel valves back in the 70's because they knew the gas was going to change. You can burn anything you want to in there!" ...
I'm like "yeah ok, the valves are going to be ok, but what about everything else?"
(I never got an answer from him on that)
Anyway, I think I might try some of that ethanol free stuff... see how it runs with it.
Otherwise, with the "normal gas" at the regular gas stations everywhere, the 87, 89, and 92 octane choices all have the same ethanol right? (up to 10%)
Would there be any difference, or benefit of running premium (92) in this car?
Sent from my iPhone using Tapatalk
Discussion Starter #172
And then of course there's the whole synthetic vs conventional dyno oil thing. I'm open to all thoughts and input on this.
As with my intrepid, I never had any issues running Mobil1 full synth in the 3.2, but this 318 is from another time. Should I stick with conventional?
(I know this debate has been going, and will continue to go on until the end of time)
The valve discussion was geared towards Unleaded Fuel. The manufacturers changed the material of the valve seats to compensate for the loss of Lead in the fuel. Ethanol and Ethanol Free are both considered unleaded fuels.
  • Like
I'd also stick with conventional oil. Both for the cost savings and reports of seals leaking on older cars when synthetic oil is used. Just get the best oil filter you can find.
  • Like
I use ethanol-free gasoline in all my vehicles and lawnmowers - have been for probably 8 or 9 years now.
Its a lot easier on the rubber and plastic parts in the fuel system, plus has more energy content. I pay more, and there's not an ethanol-free station on every corner, but I figure over the years it could make the difference in fuel system maintenance/problems. Ethanol is cheaper to the consumer only because it is tax-payer subsidized.
I find that fuel hoses on my lawnmowers definitely last a lot longer with ethanol-free fuel.
You may already know about this site where you select your state and look up your city for locations of ethanol-free gasoline: Ethanol-free gas stations in the U.S. and Canada
My wife and I know the local ones, and that's where we fill up. When we travel, we generally get the regular fuels, unless I'm traveling by myself and have the time to find a station on that web site on my iPhone and maybe drive a couple of miles out of the way. YMMV - LITERALLY!! Heh heh!
On the dino vs. synthetic oil, I think Ron is right. If you have marginal seals and gaskets, the synthetic will find them and leak. but if your seals and gaskets are in good shape, you should be fine. If you're not sure, it's a risk. Worst-case, you will end up needing to replace the bad seals and gaskets.
Some people claim that synthetic will clean away residue that helps keep seals and gaskets from leaking in older engines with dino oil. That may or may not be a myth left over from years ago when Mobil 1 came out and they had 3 or 4 years of experimenting before they got the chemical additives that control rubber expansion/contraction balanced out correctly. Many people who switched over in the early days ended up with huge oil leaks. I haven't had any leaks in either of my Concordes, my wife's '99 Buick, my '85 F150, or, you guessed it, my lawnmowers since switching to synthetic at high mileage 5 or 6 years ago
I use Shell Rotella T-6 (5W-40) in all my cars and lawnmowers, except for a brand new vehicle in which I use Pennzoil Platinum 5W-30. I made the move from dino oil (with 8 ozs. of Marvel Mystery Oil added) to synthetics as I've gotten older, mainly to spread out the oil change intervals a little (I'm still a DIY'er). T-6 is at Walmart all day long for about $21 a gallon (costs a good bit more at Advance).
The T-6 has some zinc, which has been greatly lowered in the SAE spec. for passenger car oil. Zinc gives some anti-wear advantages. (The truck SAE spec. allows a bit more zinc - the allowables for zinc content in the car and truck oils overlaps. The T-6 is in that overlap part and so meets both SAE specs.)
Discussion Starter #177
I know. I was specifically talking about ethanol, and he had a flashback or something and started telling me about how they changed things to accept the loss of lead etc.
He basically couldn't answer me about how the car "handles" ethanol. And of course it's all unleaded Ron.
Discussion Starter #178 (Edited)
Well, I decided to start using ethanol free today. Turns out there's actually two pumps; one, for "off road/marine use", (which has a higher octane rating I'm guessing) and the other for road vehicles at 89 octane.
And the car's been running so good, now that I've properly plugged that vacuum port, that I went ahead and filler her up. Let's see how she does!
Ethanol tears up older cars fuel system system components as Bill will probably verify. It doesn't happen overnight and it might be years. Benefits are more energy per gallon as Bill indicated plus the lack of corrosive Ethanol. After that it's all about the Benjamins. What's the cost difference per gallon?
You were talking about Ethanol when you made the Valve reference so I wanted to make sure we were on the same page.
  • Like
