1 - 2 of 2 Posts
Ok, I'm finally re-installing my Metra (44-PW22) power antenna.
I'm 90% done after an hours work, just need to re-run the power leads and install a relay I bought so that the antenna goes down when the trunk lid is open. Probably another 2 hours, you know how electrical work goes......
However, there is an electrical box, either a junction or a relay, about 2 inches to the rear of the antenna mounting position inside of the right-rear panel. There are four heavy 10ga wires going in and out of it, the wires are wrapped up in the same sub-harness as the antenna signal cable.
Any idea what that might be? The last time I was in that area was 2+ years ago and I must have ignored the box then.
thanks!
Oh, this install is going so damned easy and the car looks so nice without an antenna sticking up that it might be worth a short How-To. $75 (antenna from Crutchfield, short adapter cable from Circuit City), 3 hours of time, and your factory antenna stick is replaced with a black power antenna. Minimal hand tools, no scraped knuckles, etc, etc. Easy.
1 - 2 of 2 Posts
