I have a 1999 3.2L ES that stalls while driving. For example, I will be driving down the freeway at 60 to 80 and it acts like the engine shuts off. RPM's go down to 0 and the green cruise control light comes on. Then within 1/2 a second the RPM's go back up (power as usual) and the cruise light shuts off. What could be causing this? If there is a known fix what is it?
Are there any trouble codes in it? Check engine light on?
Battery connections with corrosion have been known to cause strange problems.
Clean battery posts and the big 'jump start' connections-just a shot...
re:codes-- does odometer show "done" after the inquiry?
