the same mounts as the 2.7? the conversion manual doesnt say anything about it... or maybe im, dumb:smileyvault-newhere
also- the flywheel is the same as what came in the car? i.e. 02 flywheel from 2.7/3.2/3.5 is all the same? so use the old one?
The actual motor mounts themselves (rubber isolators with the threaded studs sticking out) are the same. It is the mount-to-engine brackets that bolt from the mount to the engine block that are different between 2.7 to 3.2/5. These are removable from the engine mounts, so you can use the original rubber mounts that came with the car. So make sure your 3.5 has the engine mount brackets with it at least.
Flexplates between engines are identical 98-01, and 02-04. You can bolt your 2.7 flex plate right on your 3.5 and be done. You just cant mix and match years....IE 1999 3.5 flywheel on 03 3.5.
thats everything i needed to know. i enjoyed your manual and im going motor hunting this week and/or next "depending on...** "
so ill be picking out my motor, and all these things will need to be picked up/pried off/taken care of. im preparing lists of stuff i need to get.
the yard near me has "drop out" motors for 187+47 core.:baller:
