I am attempting to replace my fog light bulb on my 00ES. There is a screw on the lens, but it doesnt seem to let you remove the fixture to remove and replace the bulb??can someone please direct me or assist my pathatic mechanically dis-inclined azz. thanks Alexx
berggyb is correct. once you unscrew that one screw, whole assembly comes off. unsnap the back cover and you'll see a metal spring. push on it and move it to the side and the bulb comes off. reverse for install. also. if you played with the lower screw in the front, your fogs are now out of alignment.
thank you both for your Wisdom. It is said intelligence spurts growth, but wisdom grows eternally.
