http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=601353645
Ok... I decided to get the euro-style antenna cause i always felt the stock antenna just looks like ****. However, Intrepidatious pointed out to me that my stock antenna seemed to not screw down all the way on my car... we found out it was missing some grooves inside.
So i went out and got the Euro-style antenna. Well..... I thought that all the antennas would be the same... if its screws on, it would work. Well I didnt know that different car makers have different sized antenna masts.
It seems that the Chrysler antenna mast uses a bigger more proprietary one... if I try to screw the euro antenna onto it, it wont fit... the mast is too large... antenna hole is too small. In order to get this antenna on my car, I have to use this stupid coupler that comes with the antenna. Well using the coupler is dumb cause if you look closely at the pic of the intrepid... you will see the coupler is more NARROW than the antenna bottom. It looks retarted.
My question is... is there any way to take off the existing antenna mast on the intrepid and replace it with a slightly smaller one that would fit the antenna i bought? I have replacement masts... does the mast on the Intrepid screw off?
