1 - 10 of 10 Posts
I bought two subs off ebay quite some time ago. I never researched and found out what I bought so I would like to know.
If you know what these are or can give me any specs/details on if they're quality or not. I would really appreciate that.
They are 10" Kicker. the little icon says 10 and then 4ohms underneath it. I couldn't see any model numbers or anything like that.
The old Kicker Comp series, low on kickers lines of woofers but still decent, don't throw more than a few hundo at it.
depending on the box type, the amp, and what condition the equipment is... it might have been a good deal. Then again since you had no idea what you were buying He could have slapped a Kicker Decal on a pile of dog poop and you wouldnt have known any better... lol. Why would you buy a product you know nothing about?
I guess eagerness to throw something cool in my car, as lame as it sounds. I forget what type of an amp it is but I will find out and ask about it soon. It is all in really good shape. I don't know what type of box it is but it looks generic, the material is like the "fake wood" that desks and other things are made from.
old subs own, that's the 2nd year of the comps there, use to have 2x12's they banged hardcore!
Key Features:
polymineral cone
double-stitched polyester foam surround
can be used in free-air applications
frequency response 30-500 Hz
power range 35-125 watts RMS
peak power handling 250 watts
sensitivity 87.7 dB
4 or 8 ohm impedance
top-mount depth 4-3/4"
sealed box volume 1.0-2.4 cubic feet
ported box volume 1.25 - 1.75 cubic feet
Those are the specs on the most recent model of Kicker Comps and you can pretty much assume the ones you have are going to be pretty similar. I havent been able to find any information about the amp to tell you if they match up or not.
Discussion Starter #10 (Edited)
I actually found info on the amp. It seems like a pretty decent one.
# Q 3000
# Power
# 2 X 100 @ 4 Ohm
# 2 X 150 @ 2 Ohm
# 1 X 300 @ 4 Ohm Mono
# Freq Resp 20Hz-30Khz
# SN Ratio >100dB
# THD <0.05%
# Damping>[email protected]
# Channel Sep>65dB
# Dimensions (LxWxH) 6" x 10.75" x 2"
# Class AB 2 Channel Stereo Amplifier
I am going to try and sell the setup, just time to go I guess.
1 - 10 of 10 Posts
