1 - 18 of 18 Posts
I don't post a whole lot but I really need to vent a bit so....
Do you ever feel like you are so far behind in car repair chores that you will never get caught up?
I feel like I am constantly working on cars and I just never get "finished" or at least down to a managable list. All the drivers have take a back seat to my getting the GTX finished but I have kept up with oil changes and brakes but the list of repairs ahead is just getting me down, I seriously need some time off to get caught up. Here's my list, I'm sure you have your own
97 Intrepid ES
Engine cradle bushings
Bearing hubs
Air not working
(just did intake gasket, wires, plugs, stabilizer links and inner tie rod bushings)
97 Intrepid SE (not plated yet)
Brakes
Headlights just work on highbeam (they are dull enough so you don't notice)
(just did inner tie rod bushings)
96 Intrepid ES (just purchased)
Air
EGR
Needs tires
98 Durango
Front bumper and fender (got them painted, now they need to be installed)
Air, needs a new evaporator core, big PITA
Need tires before winter
(just did bearing hubs, upper and lower ball joints, inner and outer tie rod ends, trans fluid change, painted and installed a new tailgate
OK, I'm done bitching :banghead:
'97 Intrepid 3.3
-Top end currently torn apart waiting on the heads to come back from the machine shop (blown head gasket). Never done this before so I'm praying it goes back together.
-Tie rod ends (at least)
'96 Intrepid ES 3.5
-Replace timing belt and water pump because of mileage (105K)
-Replace intake gaskets (rough idle)
-Replace driver's door lock actuator
-Replace passenger side Tie Rod End (driver's side replaced but I didn't have a short 22mm socket that day so the passenger one didn't get replaced)
'93 Astro van
-Driver's side window won't roll up or down (something broken inside because you can move the glass with your hand. Window motor still works)
-Need to find a replacement passenger door lock switch
1970 Kawasaki A7 Avenger 2 stroke motorcycle
-Waiting on a used CDI unit that hopefully works
-Find and replace throttle cables
-Replace or recover seat
I share your pain
I share your pain
Nice bike. My dad has a few of the Kawasaki Triples.
1997 Dodge Intrepid 3.5L(mine)
Needs engine rebuilt/used one put in
Needs Tranny(getting 2nd gen)
Needs body work
-Rear Bumper re-done
-Pass. side fender pulled
-dents/chips pulled/covered (hood and trunk)
Needs tires put on it. Wear bars show
Needs inner tie-rods
My small list. After thats done Ill get into shaving the door handles and re-paint ;D you know, the fun stuff
Also,
1994 Geo Metro(mine)
Needs tranny work
^^^think Im just going to sell it
2000 Dodge Ram 1500(moms bf's)
Needs engine work, in the process of tracking down a miss
2005 Impala(moms)
Needs oil and other fluids done/checked
2002 Dodge Neon(sisters)
Needs a whole lot of body work
^^^^sisters car, 5 grand worth of car, not even worth 2 grand now
1998 Ford Taurus(commuter car)
Needs engine work
And tires
1 more :p
2005 Chevy 2500(sisters bfs truck)
needs air lift put in
new tires and wheels (38s i think)
Needs super charger installed
New sound system needs to be installed also
Those triples are bad ass. Don't handle for crap but in a straight line they are heart stoppers...lol
Mine is a two stroke twin that I picked up for free. I got it because except for the CDI unit it was a complete bike which is rare for something that old. I hope to have it running soon.
Finished replacing engine in brothers intrepid a few months back.
Finished replacing the engine in my mothers durango about a month ago.Along with the addition of the tow package and the Jeep nav unit.
To do list-
R/T-Brakes,plugs,timing belt/water pump.
I2's trep-Brakes, Shift kit,pcm, trans flush.
Durango-Brakes,rear window motor,Both bumpers including steel supports,Low and hi pressure p/s lines.
This week I spent some time chasing a misfire on the wifes Grand Cherokee. The bosh plats plus plugs that I put in looked like **** after only 10k, but I got my money back for them anyhow.
Next week I'm taking in another trep, a white SE with the notorious 2.7 being swapped out for......we shall see!!
Between the 3 motors I should get some decent money on all the alum once I strip them down.
I need a f'n garage, Im this close to laying a concrete pad down to work on!.
To do list-
R/T - Sway bar end links, speaker adapter install, sound deaden the rest of the vehicle, new steering rack?, install u-connect
LHS - New steering rack?, ABS pump, A/C, stereo install, install u-connect
Yup, on the 69-71 500's the CDI NEVER wants to work. My dad has a full box of the boxes that are shot lol.
Dain bramaged
just fyi to the op, there was never an offical SE 1st gen.. they were just refered to as base models.
95 intrepid
-Interior swap
- Engine Rebuild
- Transmission mount
-Rebuild new trans for swap
- LSD unit install
- Transgo kit install
- Raybestos clutch pack
- Audio System
- Front brake swap
- Es trim install and PAINT!
95 intrepid
-Interior swap
- Engine Rebuild
- LSD unit install
- Audio System
- Front brake swap
What are you going to run for a LSD?
Discussion Starter #15
So I'm not alone, feeling a bit better now
Feels like I am maitaining a fleet that is driven by a bunch of blind chimps, the stuff breaks faster than I can fix it and all the parts store employees know me
My goal is to get all these things in decent shape before the weather turns
LOL, I know how it is, Im in charge of a towing fleet...
Ive got 10,000 projects too, if you want to help me when you get done with yours, lol:
Intrepid needs trans rebuilt, band-aid on it for now
Bike needs oil change (have to take half of it apart)
Dads truck needs power steering fixed and tires
Need to find a good pickup truck for the winter
Finish F350 repairs-- not my truck
garage needs cleaned out
storage unit needs cleaned out
sort and take scrap down to the scrap yard....list goes on
Discussion Starter #17
Don't even get me started on the non car related stuff, not enough space on the internet for that list...
2 u-connects?
stereo??
Well, I'd like to install an extra u-connect harness into the LHS so I can quickly swap the mirror and module between vehicles, I'd also like to get an RB1 new stereo to older car adapter so I can swap my RB1 between vehicles.
1 - 18 of 18 Posts
