1 - 10 of 10 Posts
i want to get rid of the factory infinity amp and wire in some thing else,
is that possible to just replace it with a better amp?
i want to keep the stock radio
the factory power wires wouldn't be heavy enough, but you could use hi-low rca converter so you would have rca jacks and use the factory speaker wires. I wouldn't suggest doing it this way but it would work. anyway hope this sheds a little light for you
well, lets say i want a badass system (1000W)if i upgraded the wires could i still use the factory radio?
You will want to look up 'PAC' module. It is designed to work with the factory wiring and allow you to use aftermarket amps, etc so that you can use the factory HU with the rest being custom stuff.
1 - 10 of 10 Posts
