This post is a resolution to a problem I was having. It is now fixed. I am hoping to help someone else having a similar problem.
I have a 95 Intrepid and the flashers would not work. I checked the fuses and changed the flasher unit. Still no go. Neither the turns signals nor hazard flashers would work.
After some troubleshooting, I discovered that the flashers are powered via a small wire which attaches directly to the + terminal clamp of the battery.The wire had corroded at the clamp although it was not apparent just by looking. I had to remove the clamp from the battery terminal, remove the plastic shrink wrap from the small wire and resolder it to the terminal lug. Hope this helps.
That also happened to me bought 3 diffrent flasher arms.Now they work but the hazard button has to be pressed down or else they dont work :/
