hi guys, so before last winter i had installed HID's in my foglights in my 04 special.
and at one point they would turn on when they want...
Some times when i hit bumps or when i would pull on the switch several times lol
I took the hid's out because they wouldn't turn on anymore. So I put normal H3 bulbs and since then still nothing.
I changed the fog light relay (it clicks when turned on), I tested The fuse in the side panel (works), My ground on my fog works!
But I have no power going to the bulb! (tried with a test light). Even in the connection to the fog!
The foglight sign on the switch inside lights up when I try to turn it on.
I took a wire from the fuse in the side panel to the left fog and it worked...
Where else could i look?
What could it be??
thanks
you'll probably have to just track down the length of the wire and check for crimps/cuts/breaks..obviously make sure all your connections are tight..
