1 - 2 of 2 Posts
When I bought my 2003 dodge intrepid es The fog lights were not working. don’t know where to start for the solution of the problem … maybe you guys can help me out?
Info. for some basic checks:
Hopefully it's just blown Fuse 16 (first thing to check). Replace if blown. If fogs work and new fuse does not blow, you're done. If new fuse blows, then troubleshoot cause.
UNDERSTAND OPERATION:
3.7.4 FOG LAMP CONTROL
The body control module controls the operation of the fog lamp relay which controls the fog lamps. The fog lamps can only be on if the park or low beam headlamps are on. If the high beams are turned on, the fog lamps will automatically be turned off.
PRIME SUSPECTS:
• Fuse 16 (check fuses with ohmmeter - visual checks are not reliable)
• Fog lamp relay (can swap other same-part relay if suspect)
• Ground G106 connection
• Lamp socket corrosion
WIRING DIAGRAM:
Rectangle Font Schematic Slope Parallel
LOCATIONS OF FUSE 16 & FOG LAMP RELAY (n fuse panel behind driver's side dash end cap):
Schematic Rectangle Slope Parallel Font
LOCATION OF GROUND G106:
Triangle Slope Font Parallel Auto part
TROUBLESHOOTING PAGES IN CASE NEEDED:
Font Material property Parallel Screenshot Number
Font Parallel Screenshot Rectangle Number
  • Like
Reactions: Ronbo
1 - 2 of 2 Posts
