OK I have not seen this topic..does any one know of a direct fit replacement fog lights that will provide more output?
Thank you in advance
you can use the originals (why get rid of a good thing) just take them off, cleanm them up real good and get yourself some good high output PIAA bulbs (i think they are H3 on the vision) or some like that. Seems like a wast of $ to go with aftermarket....
If you are using the stock wiring, then you cant go higher than 55W or you'll burn out the wiring. Just so you know, if you want to go higher or brighter than that, you'll need to upgrade the wiring and probably not use the stock fog light switch.
