i was thinking about bending it till it snaped, but i started wiggling it back and forth and the ribbet started comming loose put a flat head screw driver in between the 2 metal peaces and pryed a lil bit then the ribbet came up just enough to get the screw driver under there so i did that ribbet poped out, just bent the metal peace so i could get it out and presto it was out and i started putting it back to geather.. what kind of blubs do i need to get for the fog lights cause the passenger side bulb is blown so i'll just replace both of them with some bright mofos :fun_08:
