Nice How To DIT! now i just need the couragae to go cutting wires under my dash.
intrepid1994 said:hey you forgot to reconnect the battery
Dodge_Intrepid_Teen said:reconnect your batt
Yeah you got it, make sure you tape were you cut good. Dont have it loose or anything wrap it around as tight as you can. good luck, the toggle switch will tell you like I said early Power, Ground, ACCstockho1msyndrom said:this may sound stupid, but i am a rookie. you take the three wires, connect them to the toggle switch and then reconnect the battery?
