The tip at the bottom of the article about using Mother's mag and wheel polish is bad news!!! I did it to one of my headlights and a friends and have had it turn out badly. Somehow the chemicals from the polish get into small fractures in the lens and allow moisture to get in. Entire inside of the lens was fogged over. I had to pull the housing and blow dry it out.
Whoa 04Intrepid SXT thanks for the tip / warning.
I haven't tried the headlight fix. Just stumbled on it from Allpar and since they are one of the best Chrysler sites thought I'd put it up as yet another headlight fix process.
Thanks again.
