1 - 2 of 2 Posts
Has anyone replaced there front and rear strut assembly with the ones available from JEGS PERFORMACE PARTS. KYB PLUS STRUTS. The whole assembly parts.. If so how did they perform and were they a good set.
I've got about 15k on my KYB Plus front struts. They seem fine as of now *knocks on wood*. Rear struts are almost always fine with these cars, it's the front strut mounts that tend to be the problem, as all (from what research has led) aftermarket mounts are only one side, rather then two seperate (left/right).
I bit the bullet so to speak with my KYB Plus, and have been doing good so far.
You should try emailing kyb and see if they use one strut mount, per side, or use the same one and flip the parts for the opposite side.
1 - 2 of 2 Posts
