It's been a few years since someone has posted with this problem.
I believe you need to measure your rotor diameter again. The wrong (small) rotors would be 283mm (11.14") in diameter. the correct rotors would be 297mm (11.7") in diameter. I'm thinking your rotors are 283mm (11.14"). The difference in diameters is just over 1/2", which gives you just over 1/4" of extra pad overhang. You have the correct pads. That's what I think you will find out.
A few years ago, aftermarket had the opposite rotors listed for our cars for some applications. I think they fixed the discrepancies in their applications lists eventually (I personally notified NAPA of the problem in their applications lists). But I believe that for some reason, someone put the wrong ones on your car, maybe some years ago due to the incorrect applications lists or some other reason - who knows?
Unrelated to the rotor diameter, it looks to me like you have either the wear bars or 'W' clips installed. They move the pads outward an additional 1/16" from what they'd be without those, but the 1/16" isn't that much of a difference. 1/4" mismatch from wrong rotor diameter is way more of a big deal.
If I'm correct, you need to replace your front rotors with the correct ones. You can get he correct size rotors in either outside- or inside-vented versions - either one is fine. The important thing is that you get one or the other in the larger diameter (297mm/11.7").
