1 - 12 of 12 Posts
Hello,
I have tried to find a custom bumper in my price range, because I'm not a fan of the intrepids bumper. I am also not a fan of the ES bumper, I want something along the lines of the Andy Autosport Combat body kit bumper. I talked to Andys auto sport and they are out of stock for the foreseeable future.
So my plan is that the normal SE bumper is close enough to the combat bumper for me to modify it. I am going to cut out the parts highlighted in red. I hoped to borrow the knowledge of this forum for two questions.
1 Has anyone done something similar before? What tools do you recommend? I was going to buy a Jigsaw from amazon and try to cut it.
2 What is the durability of the SE bumper? would it need any extra support once the middle is cut away?
Thanks in advance for the help everyone!
Only problem I would with cutting all that out is the fact that there will be a lot of the crash support showing through. However it could be hidden if you made up some sort of fancy grille for it.
But yeah a jigsaw should work just fine for you. Just make sure that after you cut the edges out that you sort of mold the plastic back to where it is smooth. You could either sand it (which would probably gum the sandpaper up) or maybe even try warming the bumper up with a torch or heat gun if you have one (If you do the torch method be very careful because the plastic will act like candle wax and start to melt away pretty fast if you are not careful, also doesn't feel too good if it drips on your skin).
I would imagine it would be fine, if anything you would need to make the bottom lip more rigid as it would probably just flap around in the wind. You could try making brackets that go from the inside of the bottom lip of the bumper to the radiator support. Also could try just filling the bottom lip with that insulation spray foam (worked great as far as support is concerned on a fiberglass bumper however in your case the plastic may not be rigid enough to support the weight and could just sag really bad).
Get some NAPA two part bumper repair: this will allow you to bond multiple parts, fill cracks, and ultimately sculpt details, this is a better alternative to fiber glass and bondo, since the application is on a polyurethane bumper. 220 and 320 grit sand paper will aid in the body work.
It has been done before, exactly as you state. I'd have to dig for a picture, but it looked really good.
I'd personally use a dremel tool or something else with a rotary cutting wheel.
I will put a mesh grille behind the bumper when I'm through.
What is the benefits of a dremel vs. Jigsaw?
Thanks for the replies everyone! does anyone else have anymore advice for me?
Hello,
Just Black out the center vs. cutting it apart. Sorry I don't have a better pic.
And ditch the front plate bracket.
More, more, more
NCFRC, any chance of getting a better pic of the blacked-out bumper. That sounds like a really interesting, and very do-able, approach.
I am VERY interested in following this project.
I'll try and get one as my son will be home from college with the car this weekend.
Thanks ,, The outside amber LED's also come on with Fog lights.
I think it looks really good at night as the amber marker lights and the
LED's match very good on the outside corners.
1 - 12 of 12 Posts
