1 - 2 of 2 Posts
· Registered
I was wondering if anyone knows how to remove the small piece of orange reflector in the headlights, so you can get the clear look
· Registered
I think someone was talking about that in the 1st gen forums... I don't think it's possible in the 2nd gen car. I think the edges are melted into the rest of the plastic and to remove it would require taking apart the whole assembly, which would require alot of patience and skill. Chances are, the assembly would break if you tried to disassemble it. Then, even if you got it back together, it would be hard to make sure it's completely sealed. A possible alternative would be to paint the area where the orange reflector is. You would have to make sure that the light is visible from the side at a certain brightness though to keep up with the side marker regulations.
1 - 2 of 2 Posts
