1 - 1 of 1 Posts
Car is located in Edmonton, Alberta Canada
I'm selling my 1995 Chrysler Intrepid ES 3.5L that I've had for one year. 226757km
Features:
Fully loaded - beige leather interior, two tone black and grey exterior, A/C, automatic temperature control system, overhead OTIS(compass, thermometer, distance until empty, trip counter, etc), power windows, power locks, power steering, automatic, remote starter, keyless entry, towing hitch with tranny oil cooler. Highest model of the 1st generation Intrepids.
The Good(new parts):
Previous Owner
June 30, 2001 – Transmission & Diff Flush, New Filter
Jan 28, 2002 – New Water Pump and Timing Belt
June 6, 2002 - Alignment
Nov 2, 2004 – New Water Pump and Timing Belt
Sept 8, 2004 – New P/S Pressure Hose
May 7, 2004 – Alignment
Jan 11, 2005 – New Radiator and Lower Rad Hose
Since I took ownership:
August, 2005 ATC Control Module Replacement
August 26, 2005 – Sway Bar Link Kit LH
August 26, 2005 – Sway Bar Link Kit RH
August 26, 2005 – Inner Tie Rod End LH
August 26, 2005 – Inner Tie Rod End RH
August 26, 2005 – New NGK Spark Plugs
August 27, 2005 – Outer Tie Rod End RH
August 31, 2005 – Transmission Mount
August 31, 2005 – Replacement Wheel Nut
September 1, 2005 – All 4 rotors, pads, light bulb, passenger front wheel bearing
September 16, 2005 – Alignment, Strut Elongate
October 1, 2005 – Accessory and A/C Belts
October 1, 2005 – Replacement Antenna
October 1, 2005 – New 9007 Headlight Bulbs
October 20, 2005 – Replacement Passenger front Window Regulator, used
October 30, 2005 – Replacement Hood Struts
November 29, 2005 – 4 new Motomaster SE tires
December 7, 2005 – Transmission Fluid Flush
December 11, 2005 – Fuel Filter
December 11, 2005 – Spark Plug Wires
December 11, 2005 – PCV Valve
December 12, 2005 – 1156 Signal Bulbs
December 12, 2005 - NGK Plugs
December 23, 2005 – Thermostat
December 23, 2005 – Thermostat Gasket
December 27, 2005 – PCV Hose
January 24, 2006 – Alignment – free, warranty
January 23, 2006 – Thermostat Gasket + reseal
May 27, 2006 – Radiator Cap
June 22, 2006 – Power Steering Pressure Hose
There is also a JVC KDLH-910 head unit installed - this is a CD MP3 player that takes SD cards. I don't want to part with the deck, but for an extra $200 CDN I will throw it in including a 2gig SD card. Otherwise a factory head unit will be reinstalled in its place.
I have spent more money in parts and repairs then the car is worth. It runs exceptionally well for its age. There is NO rust.
The bad:
1) Windshield is cracked. Will need replacement but is not cracked in the line of sight of the driver. Approximately $200 CDN at any local glass shop.
2) A/C Condenser has a leak. About $170 CDN for replacement, $50 CDN for new dryer(recommended with condenser replacement) and a R134a recharge at any local shop - costs vary. Prices here are for parts only assuming you DIY.
3) Intake gaskets on Intrepid's need replacement at about 200000km, easy replacement but never got around to it. I believe they are about $20 CDN for the two of them. Without them, there is a slight rough idle because of the vacuum leak created by the gaskets not being sealed properly anymore.
4) There is an occasional light clunk from the front - I've had it checked over by more mechanics then I can remember - my neighbour who is a military HD mechanic, my other neighbour who is a dealership mechanic, various repair shops, and myself mulitple times - nothing is loose and the only probable cause we all came up with is that the struts may be causing the noise. I've daily driven the car everyday, including some long highway trips and never had any issue.
5) The paint could use a really good polish. There are some door dings and the passenger side has very mild damage from the previous owner who side swiped the fender.
I'm being very honest with what I know is wrong with the car, and really its not much. I've already taken the time to price everything out and had plans to fix any remaining issues but I need a bigger vehicle(SUV) for my new job and I just don't have any extra time to finish it. I've spent ALOT of money, time, and research on this car.
I'm asking $5500 CDN obo. Call myself, Nathan @ (780)490-9008 or PM me here. Thanks for your interest!
1 - 1 of 1 Posts
